Time of day timestamp
ramgen
Post by ramgen » July 28th, 2010, 6:35 am
I cannot find the reset time VI in the Native Labview driver.
I want to reset the time because it is wrong time of day.
Re: Time of day timestamp
Post by Dale C » July 28th, 2010, 6:44 am
There is no time of day parameter on the Model 2400 series. The time is the time stamp in the buffer. This time can be one of two versions.
One is the Absolute time. This time means it is from time zero when the unit is powered up or from the time the reset time command is sent. So all data is referenced to zero time after the reset command is sent.
The other is the Relative time. This time is the time between readings.
