disable "beep" on a 24xx SMU
LV_apprentice
Country: France
Post by LV_apprentice » October 24th, 2011, 12:46 am
Hi every one !
My question is simple : How to disable the sound of a 2410 or 2425 SMU ?
I mean : each time the SMU performs a measurement, it makes a beep, which is anoying for me because I'm programming an application which performs a lot of measurement (simple voltage and current)
I use LabView and the keithley GPIB driver, and can't find how to do this...
thanks a lot for answering !
Gabriele V
Country: Italy
Re: disable "beep" on a 24xx SMU
Post by Gabriele V » October 25th, 2011, 1:28 am
command to disable beeper is:
:SYSTem:BEEPer:STATe <b> Enable or disable beeper
Parameters <b> = 1 or ON Enable beeper
0 or OFF Disable beeper
For further details please have a look a the Control Beeper Section in the 2400 User Manual.
http://www.keithley.com/support/data?asset=6103
page 18-109
regards
Gabriele
Gabriele Vittori
Application Engineer
Keithley Instruments (Italy)
LV_apprentice
Country: France
Post by LV_apprentice » October 26th, 2011, 12:06 am
thanks a lot for your anwser, that was exactly whay i was looking for !
LV_apprentice
Country: France
Post by LV_apprentice » October 27th, 2011, 12:48 am
actually this command allows you to enable or disable the "beep" which happens when you press a front panel key on the SMU,
I want to disable the beep which happens when the output is set ON... and it doesn't seems to be the same thing...
