ID CODE -113
Nighthunter
Country: Slovenia
ID CODE -113
Post by Nighthunter » November 4th, 2011, 8:16 am
I have a small problem.
I have making measurement with model 2400, but everytime I get a error -113 and I don't know what I'm doing wrong.
string send to Keithley is something like this:
:SENS:FUNC 'RES'
:SENS:RES:MODE MAN
:SENS:RES:OCOM ON
:SOUR:FUNC CURR
:SOUR:CURR 0.001
:SENS:VOLT:PROT 1
:SYST:RSEN ON
:OUTP ON
Thank you
Re: ID CODE -113
Post by Andrea C » November 10th, 2011, 5:26 am
Hi Nighthunter,
The most common cause for a -113 error is a simply syntax problem.
I ran each of your commands to a 2400 and do not see any -113 troubles.
I did experience a -221 Settings conflict when sending the :SOUR:CURR 0.001 command. This is because the instrument is on a 100uA source range and the command is asking for 1mA of source current.
Can you single step through your program and isolate which command is the offender? You probably have a missing quote or something simple.
One suggestion: first send a *RST command to put the instrument into a known state.
When the instrument is in the *RST state, source auto range is enabled. This state then allows the instrument to automatically change to an appropriate source range for the :SOUR:CURR 0.001 command.
Andrea
