Labview for 2401 to measure resistance in real time
Alfa Sharma
Post by Alfa Sharma » January 28th, 2016, 1:39 am
I want to measure resistance change with time in real time or continuously by using 2401 sourcemeter. So can i get any help about the .vi diagram for measuring resistance using LABVIEW
2401.vi
(14.52 KiB) Downloaded 1190 times
Re: Labview for 2401 to measure resistance in real time
Post by Dale C » January 28th, 2016, 6:13 am
Try this VI.
Two things were needed.
OUTPUT ON
:FORM:ELEM RES
That should help.
2401A.vi
(15.04 KiB) Downloaded 1258 times
Alfa Sharma
Post by Alfa Sharma » January 28th, 2016, 8:09 pm
Hii Dale,
Actually i'm using Labview 2013 hence the .VI u send is not opening in my system as of urs is in 15 version Labview . So can u send by other way so that i can visualize it. Thanks in Advance.
krupams
Post by krupams » September 18th, 2018, 12:13 am
Try this VI.
OUTPUT ON
:FORM:ELEM RES
That should help.
2401A.vi
Sir, Thank you. Your VI working for a GPIB interface. But when I connect the instrument using serial interface(RS232-USB), It gives errors -150, -140 (character data error and string data error)and also it says "timed out error before the operation completed....". what do I miss? (P.S: I have installed the NI serial driver. When I read through Ni MAX also, it gives the timed out error)
