Is negative on 2420 connected to earth ground?
rajmunna
Post by rajmunna » January 10th, 2012, 1:35 pm
Is 2420 -ve of input/output supply pins connected to earth ground? If so how can it be disconnected?
Raj
Nathan S
Re: Is negative on 2420 connected to earth ground?
Post by Nathan S » January 10th, 2012, 1:52 pm
The Lo Input/Output of the 2400 line is not connected to earth ground. It is spec'ed at >1 GOhm Common Mode Isolation. You can certainly tie it to ground externally if you choose, but it is designed to float up to 250Vpeak away from earth ground.
