Windows10 driver for KUSB-488B USB to GPIB
WernerHock
Re: Windows10 driver for KUSB-488B USB to GPIB
Post by WernerHock » March 21st, 2017, 8:15 am
I have the same problem with KUSB-488B and Windows 10.
Please let me know, where I can find the driver.
Thanks, Werner
Stuart M
Keithley
Keithley
Post by Stuart M » March 21st, 2017, 8:46 am
Sending you a private message now...
check your mailbox for details.
Best regards.
Dmitry
Country: Russian Federation
Post by Dmitry » March 21st, 2017, 11:22 am
Hi Stuart!
We are mount Netzsch LFA 457 machine which use KUSB-488B (with the latest driver 3.12.1) to connect the device to computer running Windows 10 32bit.
We constantly having blue screen of death after first seconds of program attempt to connect to the equipment.
Could you please send me a link to beta driver too? Hope it will help to solve connection problem.
NirSoft utility BlueScreenView shows the following information from windows dump file:
Dump File : 032117-31828-01.dmp
Crash Time : 21.03.2017 19:34:48
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 0x0014e9a7
Parameter 2 : 0x00000002
Parameter 3 : 0x00000002
Parameter 4 : 0x8173c956
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+128c74
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 10.0.14393.953 (rs1_release_inmarket.170303-1614)
Processor : 32-bit
Crash Address : ntoskrnl.exe+128c74
Stack Address 1 : ntoskrnl.exe+12c956
Stack Address 2 : USBXHCI.SYS+734d
Stack Address 3 : USBXHCI.SYS+1b1ac
Computer Name :
Full Path : C:\Windows\Minidump\032117-31828-01.dmp
Processors Count : 2
Major Version : 15
Minor Version : 14393
Dump File Size : 279 148
Dump File Time : 21.03.2017 19:37:34
Filename : halmacpi.dll
Address In Stack : halmacpi.dll+2c3edc78
From Address : 0x81c36000
To Address : 0x81c97000
Time Stamp : 0x57dacdd1
Time String : 15.09.2016 19:35:29
File Description : Hardware Abstraction Layer DLL
File Version : 10.0.14393.206 (rs1_release.160915-0644)
Full Path : C:\Windows\system32\halmacpi.dll
Filename : ntoskrnl.exe
Address In Stack : ntoskrnl.exe+13a80a
From Address : 0x81610000
To Address : 0x81c36000
Time Stamp : 0x58ba5859
Time String : 04.03.2017 9:02:01
Full Path : C:\Windows\system32\ntoskrnl.exe
Filename : USBXHCI.SYS
Address In Stack : USBXHCI.SYS+1aeb1
From Address : 0x930d0000
To Address : 0x93119000
Time Stamp : 0x57899023
Time String : 16.07.2016 4:38:43
Product Name : Операционная система Microsoft® Windows®
File Description : Драйвер USB XHCI
File Version : 10.0.14393.0 (rs1_release.160715-1616)
Full Path : C:\Windows\system32\drivers\USBXHCI.SYS
Filename : Wdf01000.sys
Address In Stack : Wdf01000.sys+fbbd6dec
From Address : 0x87200000
To Address : 0x8728f000
Time Stamp : 0x57898e1e
Time String : 16.07.2016 4:30:06
File Description : Среда выполнения платформы драйвера режима ядра
File Version : 1.19.14393.0 (rs1_release.160715-1616)
Full Path : C:\Windows\system32\drivers\Wdf01000.sys
Stuart M
Keithley
Keithley
Post by Stuart M » March 21st, 2017, 11:26 am
Dmitry,
The new driver has corrected several such issues.
check your mailbox in a few minutes for the details.
rqlumartix
Country: Switzerland
Post by rqlumartix » April 12th, 2017, 2:51 am
Hello Stuart M,
Same issue here with our KUSB-488B (connected to a SourceMetter 2401) on Windows 10 (OS restriction, we can't downgrade to window 7 unfortunately).
Is it possible to have access to the beta to test if it will solve our problem?
Best regards,
Raph
Stuart M
Keithley
Keithley
Post by Stuart M » April 12th, 2017, 7:10 am
Raph,
mcatenacci
Post by mcatenacci » April 21st, 2017, 5:28 am
Having a similar issue as the others regarding the KUSB-488B (connected to 2401 Sourcemeter) and Windows 10. Can I also get a copy of the beta driver?
-Matt
Stuart M
Keithley
Keithley
Post by Stuart M » April 24th, 2017, 6:44 am
Matt,
Johanowha
Country: Italy
Post by Johanowha » April 24th, 2017, 3:59 pm
Hey is there any chance that you can upload the file somewhere? Windows 10 64-bit here, same issue :roll:
Do not take life too seriously. You will never get out of it alive.
Stuart M
Keithley
Keithley
Post by Stuart M » April 25th, 2017, 10:30 am
The driver when released will be placed.
We are in the final stages of testing.
Meantime, I am sending you a private message now...
check your mailbox in a few minutes for the details and send us feedback when the installation is done....
olegoo
Post by olegoo » May 5th, 2017, 9:17 am
Having a similar issue as the others regarding the KUSB-488B (connected to Keithley B2987A) and Windows 10. Can I also get a copy of the beta driver?
Hai
[email protected]
Stuart M
Keithley
Keithley
Post by Stuart M » May 9th, 2017, 10:35 am
KI-488 Software Driver Version 3.12.3
The new version 3.12.3 driver has been released and is now available for direct download.
The driver adds support for Windows 10 compatibility.
It supports Keithley KUSB-488B, KPCI-488LP, and KPCI-488LPA GPIB Interfaces
Download link
http://www.tek.com/accessory/ki-488/3.12.3
esmamine
Country: Turkey
Post by esmamine » October 25th, 2017, 1:48 am
Dear Sir, Is there any driver for KUSB-488 USB to GPIB for windows 10?
Stuart M
Keithley
Keithley
Post by Stuart M » October 25th, 2017, 7:04 am
Yes there is a newly release windows 10 compatible driver.
It is now - and available for download.
The latest version is 3.13.
Here is a link to driver:
https://www.tek.com/accessory/ki-488/3.13
sergiu.bota
Country: Romania
Post by sergiu.bota » February 7th, 2018, 12:39 am
Hello Stuart M. The page wich you put with driver for KUSB-488B is not found. Can you send me email on [email protected] with the driver compatible with windows 10?
Regards
Sergiu
Stuart M
Keithley
Keithley
Post by Stuart M » February 7th, 2018, 9:13 am
Apoligies, the driver url has been changed slightly. Here is the new url:
https://www.tek.com/accessory/ki-488/3-1-3
In general we are releasing new versions of this driver periodically.
You can search the website for new versions as follows:
https://www.tek.com/product-support
click on the Downloads link on the right-side of the screen and enter the following to search:
Model or Keyword: KUSB-488B
Download Type: Software
Then press the Search button to see the results...
Or you can use this url too:
https://www.tek.com/search?keywords=KUS ... 3Asoftware
id3691
Country: Romania
Post by id3691 » October 24th, 2018, 4:53 am
Kusb-488B cannot run with the driver KI-488_v3.13.1_KI-488-3.13.1 in Windows 10 Pro 64 bit.
”KI-488 Diagnostic Tool” doesn't start. It shows the message: ”Run-time error 48 IEEE_32M.dll file not found” when start initialization for address 21.
When start ”KI-488 Configuration Utility” the message is ”the application was unable to start correctly (0xc000007b)”. :(
Stuart M
Keithley
Keithley
Post by Stuart M » October 24th, 2018, 7:13 am
The driver has been released -.
You can find it here:
The general search to find the latest KUSB-488B driver is:
https://www.tek.com/search?keywords=kus ... 3Asoftware
Currently the latest version is now version 3.13.1, which can be found:
https://www.tek.com/accessory/ki-488/3-1-3-1
id3691
Country: Romania
Post by id3691 » October 24th, 2018, 10:01 pm
The driver that I used was KI-488_v3.13.1_KI-488-3.13.1 and I tried both the NI Command Compatible Driver and the Keithley Command Compatible Driver. After installation, OS Windows 10 Pro Ver 1809 64-bit does not show that there is any problem with the driver - in Device manager it's Ok and Keithley Loader appears in the Devices.
However, as we said, the KI-488 Diagnostic Tool and KI-488 Configuration Utility do not work, indicating that something is wrong. The "Async Read Write Static" or "Change GPIB Address" examples do not work, and the same message "The application was unable to start correctly (0xc000007b)" appears, although I copied them to their folder the file gpib-32.dll.
Stuart M
Keithley
Keithley
Post by Stuart M » October 25th, 2018, 12:58 pm
Since you have posted this problem in two different areas, I have posted a response to the issue in the other (original) posting.
Please reply there with your results.
