Voltage sweep start from negative values
Posted: December 18th, 2017, 10:35 am
Hi there,
I am using Keithley 6430 as a voltage source to provide voltage sweep from -100V to +100V. However, I found the voltage sweep range cannot be set as negative values from the front panel. Is keithley 6430 capable of doing it? If so, how to do it?
Thank you!
Re: Voltage sweep start from negative values
Posted: January 5th, 2018, 8:53 am
by Dave W
Hi dgbbo,
Yes you certainly can. What you will need to do is while setting the start/stop voltages you will need to press the little blue EDIT button and then press the CONFIG button which has the little blue +/- over it. This will change the value between positive an negative.
