infinite sweep set remotely and triggered by the trigger link
FedericoP
Country: Switzerland
Post by FedericoP » January 31st, 2018, 1:28 pm
Hi all,
I need to create a square wave with a Keithley 2410 initially triggered by the trigger link.
I guess the easiest (perhaps the only one) is to use an infinite sweep.
I would like to set all the parameters of the sweep remotely and get the sequence started by the external trigger link.
I have few questions:
1. what is the right sequence of commands to have an infinite sweep? I am following the example in the manual, but there is no command for an infinite count of sweep. Do I need to set the arm count to infinite?
2. What are the correct remote settings for triggering the sweep by the trigger link? Note: I need the trigger link only to start the sweep, then the sweep will loop until I stop it.
Any help on this will be very much appreciated.
Cheers
Federico
