Low leakage female BNC to single banana?
Boyan Boyanov
Post by Boyan Boyanov » March 11th, 2018, 3:01 am
Can anyone recommend low-leakage female BNC to single banana plug adapters that work well with the ports on the 2400? Until yesterday I was using ones from Pomona (model 1894, https://www.digikey.com/product-detail/ ... -ND/745046) until I discovered that the resistance between the banana plug and the BNC shield is only 1 MOhm. I need something at least 10x better, and ideally >100MOhm. The dual banana plug adapters that Pomona makes (https://www.digikey.com/product-detail/ ... -ND/603922) easily meet that spec, but are awkward to work with in a 4-wire configuration where the routing gets tricky.
Thanks!
Users browsing this forum: Bing [Bot] and 5 guests
