2450 Sourcemeter Hysteresis Sweep
appleSwell
Post by appleSwell » June 9th, 2018, 10:25 pm
Hi, I'm trying to perform a simple current-voltage Hysteresis sweep measurement. I'm programming with LabVIEW, starting off of the example VIs that can be found -. I tried using a series of 'Sweep and Acquire Measurement' VI to make it sweep linearly from 0 to x volts, x to -x volts, and -x to 0 volt. However, there is a delay between each sweep, which I want to avoid and have a continuous sweep across all sets of range.
I decomposed the 'Sweep and Acquire Measurement' VI and went down to SCPI command level, using this command ":SOUR:SWE:LIN." However, if I naively give the command with different starting/stop level in series, only the last command's data gets stored in the buffer. Can someone please help me out how to perform a sequence of linear sweeps without delays in-between?
Lastly, I then tried to use 'Read Multiple' VI, in which I supposedly give a list of voltage levels I want the sourcemeter to sweep across. Generating a list of numbers is certainly doable in LabVIEW, but I just don't understand this VI (attached screenshot). Where do I actually put the list? Is it the "manual range"? Why is it just one number then?
I'd greatly appreciate any help. Thank you in advance!
Screen Shot 2018-06-10 at 1.18.14 AM.png (229.82 KiB) Viewed 2029 times
