ke_2450 driver crashes in simulation mode
uvonceumern
Post by uvonceumern » October 30th, 2018, 1:13 am
I installed the IVI-C/IVI-COM driver package for the SMU 2461 as well as the required IVI, VISA and NI packages.
I set up a small example to load the driver in simulation mode and it crashes as soon as I try to send a trigger abort.
// init with simulation mode on
IviDCPwr_InitWithOptions(const_cast<ViRsrc>(logicalName.c_str()), VI_TRUE, VI_TRUE, "Simulate=VI_TRUE", &vi);
// this works:
IviDCPwr_self_test(vi, &selfTestResult, selfTestMessage);
// this crashes:
IviDCPwr_Abort(vi);
To understand what was going on I made the effort and compiled the driver with debug information and the crash happens here:
inline HRESULT CIoSession::WriteStringNoPoll(const CString& strData, bool bFlush, long lTimeout)
	if (!Initialized()) return m_pErrReporter->NotInitialized();
Unhandled exception thrown: read access violation.
this->**m_pErrReporter** was nullptr. occurred
Apparently m_pErrReporter is null. It seems like it is never initialized when simulation is enabled.
Surely this is not intended behavior? Please advice.
uvonceumern
Re: ke_2450 driver crashes in simulation mode
Post by uvonceumern » November 9th, 2018, 2:29 am
BUMP, any chance I could get an answer from the team?
Users browsing this forum: dcribeiro and 2 guests
