Remote programming of Output enable lines?
wgilbert
Post by wgilbert » February 18th, 2011, 3:41 pm
I am just about to ship my system incorporating a 2410 sourcemeter. The last thing I did was wire up pins 8 and 9 of the DIO connector to a set of dry relay contacts to create a safety interlock when the fixture enclosures are opened. It works fine when programmed and operated from the front panel, but when I'm running the 2410 with my Labview test app through the serial port, it ignores the interlock.
Can you tell me what command is used to control this feature remotely, or better, which of the Labview driver vi's is overwriting or interfering with the interlock? I scanned the SCPI reference but didn't see what I need (yet).
Bill Gilbert
William Gilbert, EM Tech
Univ of Minnesota Physics
Re: Remote programming of Output enable lines?
Post by Dale C » February 22nd, 2011, 6:02 am
Hi Bill,
The SCPI command to control the output enable(interlock) is
:OUTPUT:ENABLE:STATE ON/OFF
On default it is set to OFF. Which means that Interlock capability is disabled so pins 8 and 9 would not matter.
Any Labview sub VI that resets the unit would disable this feature.
Hope this helps.
wgilbert
Post by wgilbert » February 23rd, 2011, 10:12 am
Just got round to checking on the thread. Thanks, Dale! I'll dig through and modify one of the drivers if necessary, can post back to you if you like.
wgilbert
Post by wgilbert » February 23rd, 2011, 10:51 am
I guess this should have been obvious, but maybe it was just late on a Friday afternoon when I looked for this. I've attached my vi(LV2009) for anyone who cares to use it, seems to work fine.
Output Interlock.vi
(14.93 KiB) Downloaded 1431 times
