Making a custom list sweep using the trigger link
breinoso
Post by breinoso » May 27th, 2011, 3:46 pm
Hello:
I am trying to program the 2400 to be able to sweep voltage at specific steps ( a list of 10 values for instance). I need to be able to present each value after a trigger event via the tlink #1. The trigger events might not occur at a fixed rate. I have multiple 2400 that will receive this signal from a pattern generator. Is there some SCPI code anyone can share that can give me a starting point?
Bautista
:geek:
Re: Making a custom list sweep using the trigger link
Post by Dale C » June 9th, 2011, 8:00 am
The Model 2400 can output a pulse at either the Source , Delay or Measure Cycle in the TRIGGER Layer.
Each of these can output a pulse or none of them. But only one at time.
The commands are as follows...
:TRIG:OUTPUT SOURCE
:TRIG:OUTPUT DELAY
:TRIG:OUTPUT SENSE
Do this in a LIST sweep.
*RST
:SOUR:FUNC:MODE VOLT
:SOUR:LIST 1,2,3,4,5,6,7,8,9,10
:TRIG:COUNT 10
:TRIG:OUTPUT SENSE
:SOUR:VOLT:MODE LIST
:OUTPUT ON
:INIT
That should output a pulse at each step on the SENSE(Measurement) phase.
