How to use labtracer 2.0 to fulfil the cable guard
wjy617
Post by wjy617 » November 8th, 2010, 2:09 pm
I would like to use the Labtracer 2.0 to fulfill the cable-guard IV measurements on a Keithley 2400 SMU. But when I run the program, it is always using the front terminal to output even I initially switched to the rear terminals by pressing the FRONT/REAR key on the font panel. Hope someone could help me out. Thanks
Re: How to use labtracer 2.0 to fulfil the cable guard
Post by Dale C » November 9th, 2010, 6:39 am
Cable guard is the default guard on the 2400 series.
Labtracer inherently sets the unit to front panel terminals.
There is no control for front/rear panel terminal input/output with Labtracer.
It is simply just for front panel terminals.
wjy617
Post by wjy617 » November 9th, 2010, 12:41 pm
Hi Dale, thanks for your reply. But I still have question on how to get the cable-guard measurement. If I can only connect to the front panel by using labtracer,I will not be able to use the cable guard in the rear panel. Is there any way I can get the cable-guard measurement by still using labtracer?
Post by Dale C » November 9th, 2010, 1:40 pm
I don't believe you need to use the rear panel In/out terminals when using cable guard.
Just use the front panel in/out terminals.
Now route the rear panel guard terminal to the where you need it.
It still is guard when using either front or rear terminals.
Do you follow this?
