Continuous Ramp using GPIB
ebarrios4
Post by ebarrios4 » July 19th, 2011, 1:27 pm
I am currently controlling a Keithley 2425 using SCPI commands through ATEasy. I tried using the command sequence for source-measure example in page 1-15 of the Quick Start Guide. Every time I send the command sequence with an increment in voltage level, the output toggles OFF and ON before the next voltage level is set. What command sequence can I use in order to not have the output toggle OFF and instead staircase to the next voltage.
I am aware of the Sweep function, but I need other to designate other equipment to do other functions while the SMU is still at a specific voltage level. Put simply, I just really need to avoid to avoid the output turning OFF when changing the voltage level. Essentially I want to mimic what happens when the SMU is controlled manually with the output ON and one presses the UP and DOWN arrow keys to adjust the voltage level.
Thank You
Re: Continuous Ramp using GPIB
Post by Dale C » July 20th, 2011, 5:57 am
Here is the code I used to do this...
*RST
:SOUR:FUNC VOLT
:SOUR:VOLT:MODE FIX
:SOUR:VOLT:RANG 20
:SOUR:VOLT:LEV 10
:SENS:FUNC 'CURR'
:SENS:CURR:PROT 10e-3
:SENS:CURR:RANG 10e-3
:OUTPUT ON
:READ?
Now read the data
Now send
:SOUR:VOLT 9
Notice the unit goes to 9V
:SOUR:VOLT 8
Notice the unit goes to 8V.
And so on...
ebarrios4
Post by ebarrios4 » July 20th, 2011, 1:33 pm
This is what I needed.
Thank you for the help :D
