HOW to set the range of MEAS current excceed 1A on 2430
Jacky_80
Country: China
Post by Jacky_80 » August 10th, 2011, 7:24 pm
Hello, dear expert,
I met one problem on the output current. when we source 28V on our EVB and measure the current, the max current was Clamped at 1049.9mA when our real current should be about 1.6A. so our sample didn't work normally. could we change the current measurement range to a higher level. we noticed that the biggest clamp current on 2430 was 3A, how could we get our EVB work normally using Source Meter 2430?
Thanks!
Nathan S
Re: HOW to set the range of MEAS current excceed 1A on 2430
Post by Nathan S » August 11th, 2011, 5:58 am
The power envelope of the 2430 is what is limiting you. The 2430 can source/sink up to 3A DC at voltages up to +/-21V. Above 21V, it can only source/sink +/-1.05A DC up to +/-105V.
The data sheet available for download here can explain this graphically: http://www.keithley.com/support/data?asset=372
Page 2 of that PDF has the graphs that represent the power envelopes.
Jacky_80
Country: China
Post by Jacky_80 » August 11th, 2011, 6:31 pm
Thank you so much, I have got the measure range.
