Increasing NPLC causes lockup
John Roehling
Post by John Roehling » August 15th, 2011, 5:59 pm
I'm trying to run a sweep Voltage sweep, measure current and retrieve the data. When I'm using an NPLC value of 0.7 or less and 600 points...everything is fine. But when I increase the NPLC above 0.7 with this many points, it locks up and doesn't retrieve the data (using :TRAC:READ?). Also, if I use an NPLC of 1.0 and lessen the number of points, it works fine again.
Is there some sort of timeout limit I am reaching causing a lockup? I can't find any sort of information about this in the Keithley manual, or where I have looked -.
Nathan S
Re: Increasing NPLC causes lockup
Post by Nathan S » August 16th, 2011, 6:31 am
How are you controlling the 24XX? Are you using LabView or another program? Which model is this? I'm wondering if there is just a general GPIB timeout issue happening. Personally to read the buffer I use :TRAC:DATA?
The issue likely is the time to take those amount of points at that NPLC, you'll need some sort of a software delay between the INIT that is sent to trigger the sweep to occur and when you try to read the buffer.
John Roehling
Post by John Roehling » August 16th, 2011, 4:04 pm
I am using the Keithley 24XX.vi program downloaded from this website for Labview 8.5. I figured out what the problem was, the "GBIB Read" command in labview was timing out since the sweep was taking so long. I just had to feed it a "0" for the timeout so it wouldn't time out.
Also, I am using ":TRAC:DATA?" to readout the data, I just mis-typed it.
