2430, measure problem in pulse mode
nicola.bellaio
Country: Italy
Post by nicola.bellaio » August 29th, 2011, 6:06 am
Hi all,
I want measure an RDSon with a KE2430 in pulse mode.
If I do the operations manually (setup the instrument, do the measure) I obtain the right values..
If I do the operation remotely (through Labview), the measure fail.
The strange thing, for me, is that on the 2430 display the righ value is screened out, but on the pc I obtain random values..
Did somebody has had the same problem? Or have done differently this type of measurement?
Thanks in advance
Nicola
Re: 2430, measure problem in pulse mode
Post by Dale C » September 2nd, 2011, 7:07 am
Can you post the Labview code?
Maybe with that I can duplicate the issue and find the solution.
What version of Labview are you using?
