Max Number of Pulses
tdeangel
Post by tdeangel » December 21st, 2011, 2:38 pm
I am using PulseIMeasureV from the front panel of a 2601A and seem to be limited to 1000 pulses. I want to pulse 20 ma with an on and off time of 0.5 seconds. How do I get an unlimited number of pulses?
Nathan S
Re: Max Number of Pulses
Post by Nathan S » December 22nd, 2011, 6:50 am
If you wish to use that same code, you can use Test Script Builder to Import Existing Project from Instrument. Import the Factory/KIPulse project. You can then rename the project to your own name and change the max pulse value in the lines of code where the PulseIMeasureV function is.
Hope this helps.
tdeangel
Post by tdeangel » December 22nd, 2011, 9:25 am
Nathan. ThanK you. You will see I am not an expert in this area. I assume that I have to do the import from TSB and that I cannot use TSP express or TSB embedded. TSP express and
TSB embedded work but I cannot get the computer to communicate with the instrument using TSB. I currently have the computer and instrument connected with the cross over LAN cable. If I am in TSB the system can't find the instrument. Can you help.
Users browsing this forum: Bing [Bot] and 10 guests
