how to store last reading of Buffer
Pooja_m
Post by Pooja_m » September 19th, 2016, 1:09 am
I need to store the last reading of the buffer in some local variable, I need to compare it with previous reading(last reading of the same buffer).
In my command I used
 Ig_now = GSMU.nvbuffer1[n]
Please suggest me further modification.
PS: this is my first TSP programming.
Vince W
Re: how to store last reading of Buffer
Post by Vince W » November 23rd, 2016, 11:12 am
Hi!
This seems like it will work, but what is the variable n? I don't know what GSMU is being set to, I assume something like
GSMU = smua
--or
GSMU = node[1].smua
Can we assume that you are setting
n = GSMU.nvbuffer1.n
This also assumes that smua.nvbuffer1 is measuring the desired parameter (current or voltage).
