2636B generate current single pulse
wq1134404729
Country: Algeria
Post by wq1134404729 » February 27th, 2017, 10:26 pm
Progamming by TSB,why happen this error?
jaime_g
Re: 2636B generate current single pulse
Post by jaime_g » February 28th, 2017, 3:23 pm
I noticed the number of points in the PulseSweepISingle is set to 11. For a single pulse this should be set to 1.
Here is a script I use for a single 1ms, 10mA pulse using channel B:
reset()
display.screen = display.SMUB
display.smub.digits = display.DIGITS_4_5
smub.sense = smub.SENSE_REMOTE
smub.measure.nplc = 0.001
smub.source.autorangei = smub.AUTORANGE_OFF
smub.source.rangei = 1e-3
smub.source.leveli = 0
smub.source.limitv = 10
smub.measure.rangev = 10
--Configure trigger to take a measurement in the middle of the pulse
trigger.timer[1].delay = 500e-6
trigger.timer[1].stimulus = smub.trigger.ARMED_EVENT_ID
trigger.timer[1].count = 1
trigger.timer[1].passthrough = false
--Configure trigger to turn off the pulse after 1 ms
trigger.timer[2].delay = 1e-3
trigger.timer[2].stimulus = smub.trigger.ARMED_EVENT_ID
trigger.timer[2].count = 1
trigger.timer[2].passthrough = false
--Arm trigger for single iteration
smub.trigger.arm.count = 1
--Configure source
smub.trigger.source.stimulus = smub.trigger.SWEEPING_EVENT_ID
smub.trigger.source.action = smub.ENABLE
smub.trigger.source.listi({1e-3})
smub.trigger.source.limitv = 10
--Configure measurement
smub.trigger.measure.stimulus = trigger.timer[1].EVENT_ID
smub.trigger.measure.action = smub.ENABLE
smub.trigger.measure.v(smub.nvbuffer1)
--Configure pulse turn off
smub.trigger.endpulse.stimulus = trigger.timer[2].EVENT_ID
smub.trigger.endpulse.action = smub.SOURCE_IDLE
smub.source.output = smub.OUTPUT_ON
smub.trigger.initiate()
waitcomplete()
print(smub.measure.v(smub.nvbuffer1))
smub.source.output = smub.OUTPUT_OFF
Hope this helps.
Jaime Arevalo
wq1134404729
Country: Algeria
Post by wq1134404729 » March 2nd, 2017, 5:50 pm
jaime_g wrote:I noticed the number of points in the PulseSweepISingle is set to 11. For a single pulse this should be set to 1.
reset()
--Configure source
waitcomplete()
Hope this helps.
Jaime Arevalo
Thank you! Using your code,I noticed that this program occurs new error.
Post by Andrea C » March 2nd, 2017, 7:52 pm
Which exact model number do you have?
From the TSP> prompt, please send *idn? and post response.
jaime_g
Post by jaime_g » March 3rd, 2017, 10:55 am
I reviewed the code and found some errors with the measurement timer configuration. :(
Here is an improved version:
reset()
display.screen = display.SMUA
display.smua.digits = display.DIGITS_4_5
display.smua.measure.func = display.MEASURE_DCVOLTS
smua.sense = smua.SENSE_REMOTE
smua.source.func = smua.OUTPUT_DCAMPS
smua.source.autorangei = smua.AUTORANGE_OFF
smua.source.rangei = 10e-3
smua.source.leveli = 0
smua.source.limitv = 10
smua.measure.nplc = 0.01
smua.measure.autorangev = smua.AUTORANGE_OFF
smua.measure.rangev = 20
smua.measure.autozero = smua.AUTOZERO_ONCE
smua.measure.count = 1
smua.nvbuffer1.clear()
--Configure trigger count
smua.trigger.arm.count = 1
smua.trigger.count = 1
smua.trigger.arm.stimulus = 0
--Configure pulse width timer
trigger.timer[1].delay = 1e-3
trigger.timer[1].stimulus = smua.trigger.ARMED_EVENT_ID
--Configure measurement timer
trigger.timer[2].delay = 500e-6
trigger.timer[2].stimulus = smua.trigger.SOURCE_COMPLETE_EVENT_ID
--Configure source action
smua.trigger.source.listi({10e-3})
smua.trigger.source.limitv = 20
smua.trigger.source.action = smua.ENABLE
smua.trigger.source.stimulus = 0
--Configure measurement action
smua.trigger.measure.stimulus = trigger.timer[2].EVENT_ID
smua.trigger.measure.action = smua.ENABLE
smua.trigger.measure.v(smua.nvbuffer1)
--Configure end of pulse action
smua.trigger.endpulse.stimulus = trigger.timer[1].EVENT_ID
smua.trigger.endpulse.action = smua.SOURCE_IDLE
smua.trigger.initiate()
waitcomplete()
printbuffer(1,1,smua.nvbuffer1)
Hope this one works better for you.
Jaime Arevalo
