Smu hangs waiting for tsplink trigger
[email protected]
Country: Singapore
Post by [email protected] » October 3rd, 2018, 7:42 am
I finally trying to run my script in production, but after about 6000 test cycles one of the nodes(other than node 1) in my stack of 5 hangs waiting for tsplink trigger 1. since i am running independent scripts in all nodes to save up on setup times, I use the tsplink trigger[1] (launched by node 1 )to synchronize all of them with amazing results. however, when I try to deploy for wafer level test i face this issue which was not available during development.
here is diagram of my program. FYI, when i run RunParallelTests() to test 9 locations at the same time. each location corresponds to a channel.
image url: https://imgur.com/a/wQQS8Ml
Please advise me on how to fix this bug
here is how i release the tsplink.trigger[1] from node 1 after it has finished setting up its trigger.initiates.
 d2ScriptString = d2ScriptString .. "if tsplink.node == MainNode then "
 d2ScriptString = d2ScriptString .. "delay(7.5E-4) "
 d2ScriptString = d2ScriptString .. "tsplink.trigger[1].assert() "
 d2ScriptString = d2ScriptString .. "else "
 d2ScriptString = d2ScriptString .. "tsplink.trigger[1].wait(50e-3) "
 d2ScriptString = d2ScriptString .. "end "
I have tried increasing the delay to 5ms before i issue the tsplink.trigger[1].assert() but the issue still persists.
Users browsing this forum: Google [Bot], venjense and 4 guests
