2612B dual sweep interrupt
hospseat
Country: South Korea
Post by hospseat » November 27th, 2018, 10:51 pm
Hi! I'm trying to make a dual sweep script by modifiying the example script KE26XX_Pulsed_Sweep_Dual.
Current sweep are done on channel a and constant voltage is applied on channel b.
IV measurement should be done on both channels.
When I run this script, it stops during the sweep.
For example, when the current is swept from 0 to 10 mA, it stops at channel a current of 6mA.
I assigned smub.trigger.ARMED_EVENT_ID to the timer1 stimulus.
Could you give me tips how to modify this script?
Thanks in advance.
Choi
Title: KE26XXB Pulsed Sweep Dual PC & m-PD
Description: This example demonstrates how to synchronize pulsed
sweeps between two SMU channels on a dual channel Series 2600B
SourceMeter instrument. This example performs linear sweeps but
can easily be modified to perform log or list sweeps. This
example also programs both SMUs to source the same levels
however, this can also easily be modified for each SMU to output
different levels.
There are two functions contained in this example script. One
function outputs pulsed voltage sweeps while the other performs
pulsed current sweeps.
At the conclusion of the sweeps the data is returned to the
instrument console in a format that is compatible for copy and
paste into Microsoft Excel.
Equipment Needed:
1x Dual Channel Series 2600B SourceMeter instrument
Script Functions:
PulsedSweepVDual(start, stop, numPoints, pulseWidth, pulsePeriod, limitI, nplc, remoteSense)
PulsedSweepIDual(start, stop, numPoints, pulseWidth, pulsePeriod, limitV, nplc, remoteSense)
Name: PulsedSweepVDual(start, stop, numPoints, pulseWidth, pulsePeriod, limitI, nplc, remoteSense)
Description:
This function performs synchronized pulsed linear voltage sweeps
on dual SMU channels.
Parameters:
start: The voltage level of the first step in the sweep in volts
stop: The voltage level of the last step in the sweep in volts
numPoints: The number of points in the sweep
pulseWidth: The width of the pulse in seconds
pulsePeriod: The time from the start of one pulse to the start of the next pulse
limitI: The current limit of the pulse in amps
nplc: The measurment aperture setting in PLCs where 1 PLC = 1/60 s for 60Hz power
remoteSense Set to true to enable 4-Wire (Kelvin) measurements or to false for 2-Wire measurements
Notes:
After calling this function you will need to press the TRIG button
on the instrument's front panel to trigger the sweep to start.
The code can easily be modified to trigger off other sources as
well.
Example Usage:
PulsedSweepCh1ICh2VDual(0, 0.01, 0, 11, 1e-3, 1e-3, 0.1, 0.001, 0.001, false)
function PulsedSweepCh1ICh2VDual(start, stop, bias, numPoints, pulseWidth, pulsePeriod, limitV, limitI, nplc, remoteSense)
-- function PulsedSweepCh1ICh2VDual(start, stop, lists, bias, numPoints, pulseWidth, pulsePeriod, limitV, limitI, nplc, remoteSense)
reset()
-- Configure Channel A Settings
smua.reset()
smua.source.func = smua.OUTPUT_DCAMPS
if remoteSense == true then
smua.sense = smua.SENSE_REMOTE
else
smua.sense = smua.SENSE_LOCAL
end
smua.source.autorangei = 0
smua.source.rangei = math.max(math.abs(start), math.abs(stop))
smua.source.leveli = 0
-- Set the DC bias limit. This is not the limit used during the pulses.
smua.source.limitv = 0.1
-- Disabling Auto-Ranging and Auto-Zero ensures accurate and consistent timing
smua.measure.autozero = smua.AUTOZERO_ONCE
smua.measure.autorangev = 0
smua.measure.rangev = limitV
smua.measure.nplc = nplc
-- A timer will be used to set the measure delay and synchronize the measurement
-- between the two SMUs so set the built in delay to 0.
smua.measure.delay = 0
-- Prepare the Reading Buffers
smua.nvbuffer1.clear()
smua.nvbuffer1.collecttimestamps= 1
smua.nvbuffer2.clear()
smua.nvbuffer2.collecttimestamps= 1
-- End Channel A Settings
-- Configure Channel B Settings
smub.reset()
smub.source.func = smub.OUTPUT_DCVOLTS
smub.sense = smub.SENSE_REMOTE
else
smub.sense = smub.SENSE_LOCAL
end
smub.source.autorangev = 0
smub.source.rangev = math.abs(bias)+1
smub.source.levelv = 0
smub.source.limiti = 0.001
smub.measure.autozero = smua.AUTOZERO_ONCE
smub.measure.autorangei = 0
smub.measure.rangei = limitI
smub.measure.nplc = nplc
smub.measure.delay = 0
smub.nvbuffer1.clear()
smub.nvbuffer1.collecttimestamps= 1
smub.nvbuffer2.clear()
smub.nvbuffer2.collecttimestamps= 1
-- End Channel B Settings
-- Configure the Trigger Model
-- Pressing the TRIG button on the front panel will trigger the sweep to start
display.trigger.clear()
-- Timer 1 controls the pulse period
trigger.timer[1].count = numPoints > 1 and numPoints - 1 or 1
trigger.timer[1].delay = pulsePeriod
trigger.timer[1].passthrough = true
trigger.timer[1].stimulus = smub.trigger.ARMED_EVENT_ID
-- trigger.timer[1].stimulus = display.trigger.EVENT_ID
-- Timer 2 controls the measurement
trigger.timer[2].count = 1
-- Set the measure delay long enough so that measurements start after the pulse
-- has settled, but short enough that it fits within the width of the pulse.
trigger.timer[2].delay = pulseWidth - (1/localnode.linefreq)*nplc - 60e-6
trigger.timer[2].passthrough = false
trigger.timer[2].stimulus = trigger.timer[1].EVENT_ID
-- Timer 3 controls the pulse width
trigger.timer[3].count = 1
trigger.timer[3].delay = pulseWidth
trigger.timer[3].passthrough = false
trigger.timer[3].stimulus = trigger.timer[1].EVENT_ID
-- Configure SMUA Trigger Model for Sweep
smua.trigger.source.lineari(start, stop, numPoints)
-- smua.trigger.source.listi(lists)
smua.trigger.source.limitv = limitV
smua.trigger.measure.action = smua.ENABLE
smua.trigger.measure.iv(smua.nvbuffer1, smua.nvbuffer2)
smua.trigger.endpulse.action = smua.SOURCE_HOLD
smua.trigger.endsweep.action = smua.SOURCE_IDLE
smua.trigger.count = numPoints
smua.trigger.arm.stimulus = 0
smua.trigger.source.stimulus = trigger.timer[1].EVENT_ID
smua.trigger.measure.stimulus = trigger.timer[2].EVENT_ID
smua.trigger.endpulse.stimulus = trigger.timer[3].EVENT_ID
smua.trigger.source.action = smua.ENABLE
-- Configure SMUB Trigger Model for Sweep
smub.trigger.source.linearv(bias, bias, numPoints)
smub.trigger.source.limiti = limitI
smub.trigger.measure.action = smub.ENABLE
smub.trigger.measure.iv(smub.nvbuffer1, smub.nvbuffer2)
smub.trigger.endpulse.action = smub.SOURCE_HOLD
smub.trigger.endsweep.action = smub.SOURCE_IDLE
smub.trigger.count = numPoints
smub.trigger.arm.stimulus = 0
smub.trigger.source.stimulus = trigger.timer[1].EVENT_ID
smub.trigger.measure.stimulus = trigger.timer[2].EVENT_ID
smub.trigger.endpulse.stimulus = trigger.timer[3].EVENT_ID
smub.trigger.source.action = smub.ENABLE
-- End Trigger Model Configuration
smub.source.output = smub.OUTPUT_ON
-- Start the trigger model execution
smua.trigger.initiate()
smub.trigger.initiate()
-- Sweep will not start until the TRIG button is pressed
-- Wait until the sweep has completed
waitcomplete()
smub.source.output = smub.OUTPUT_OFF
-- Print the data back to the Console in tabular format
print("Time\tSMUA Voltage\tSMUA Current\tSMUB Voltage\tSMUB Current")
for x=1,smua.nvbuffer1.n do
-- Voltage readings are in nvbuffer2. Current readings are in nvbuffer1.
print(smua.nvbuffer1.timestamps[x], smua.nvbuffer2[x], smua.nvbuffer1[x], smub.nvbuffer2[x], smub.nvbuffer1[x])
end
end
Re: 2612B dual sweep interrupt
Post by Andrea C » December 4th, 2018, 4:53 pm
I cannot see any trouble in the code.
Can you provide example of the parameters that you use when you call the function?
In particular I wonder about the nplc and the pulse timing. The script does not have any logic to enforce compatibility for these aspects of the state machine timing.
hospseat
Post by hospseat » December 4th, 2018, 5:13 pm
The typical condition is PulsedSweepCh1ICh2VDual(0, 0.01, 0, 11, 1e-3, 1e-3, 0.1, 0.001, 0.001, false) as shown on the code.
The nplc is 0.001 and pulse width and period are 1e-3 to apply dc only.
In addition, smua and smub trigger.endpulse.action are set to be SOURCE_HOLD.
Can these conditions make any problem?
Thank you for reply.
Choi
Post by Andrea C » December 5th, 2018, 4:00 am
The script assumes that Pulse Period should be larger than Pulse Width.
hospseat
Post by hospseat » December 9th, 2018, 2:19 am
As Andrea commented, the pulse width was the cause of interruption.
Thanks for help.
