TSP Express Unable to Launch
pcavas
Country: United Kingdom
Post by pcavas » January 17th, 2019, 10:15 am
I am using a Keithley 2612B system with firmware version 3.2.2. It's connected to a computer and the Virtual Front Panel is working fine, but when I try to launch TSP Express I get the following error: "Unable to Launch the Application". I am using Java 8 and Internet Explorer 11, Java Plug-in is enabled. I have administrator privileges in the computer and added my instrument's IP addresses to the Java's Safe Site List button. Any suggestions on what I should do?
Re: TSP Express Unable to Launch
Post by Dale C » January 22nd, 2019, 10:42 am
Try this...
Cannot open or access TSP Express with 2600B series SMU.
What internet browser are you using?
Looks like Firefox is the only one that supports Java.
I think that might be the issue.
Firefox 52 ESR is available.
Unlike the regular Firefox, the ESR (Extended Support Release) series will not have all the latest features, but still will support java until May 2018.
https://www.mozilla.org/en-US/firefox/o ... tions/all/
You could download that and disable automatic updates and you should be good to go.
b154b154
Country: Portugal
Post by b154b154 » May 23rd, 2019, 6:14 am
I´m having the some problem.
I tried the Firefox ESR, and it is worst, neither the virtual panel works.
The detail log is:
Exception tab:
java.net.SocketException: Unexpected end of file from server
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.access$200(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection$9.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessController.doPrivilegedWithCombiner(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at com.sun.deploy.net.HttpUtils.followRedirects(Unknown Source)
at com.sun.deploy.net.BasicHttpRequest.doRequest(Unknown Source)
at com.sun.deploy.net.BasicHttpRequest.doHeadRequestEX(Unknown Source)
at com.sun.deploy.cache.ResourceProviderImpl.checkUpdateAvailable(Unknown Source)
at com.sun.deploy.cache.ResourceProviderImpl.isUpdateAvailable(Unknown Source)
at com.sun.deploy.cache.ResourceProviderImpl.getResource(Unknown Source)
at com.sun.javaws.Launcher.updateFinalLaunchDesc(Unknown Source)
at com.sun.javaws.Launcher.prepareToLaunch(Unknown Source)
at com.sun.javaws.Launcher.launch(Unknown Source)
at com.sun.javaws.Main.launchApp(Unknown Source)
at com.sun.javaws.Main.continueInSecureThread(Unknown Source)
at com.sun.javaws.Main.access$000(Unknown Source)
at com.sun.javaws.Main$1.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
and the console tab:
Java Web Start 11.211.2.12 x86
Using JRE version 1.8.0_211-b12 Java HotSpot(TM) Client VM
User home directory = C:\Users\dep
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
0-5: set trace level to <n>
#### Unexpected end of file from server
#### Java Web Start Error:
Any suggestion?'
kind regards
P Lopes
Stuart M
Keithley
Keithley
Post by Stuart M » May 30th, 2019, 7:13 am
Java 8 and newer browsers do not work.
Here's what still works...
32-bit browser
Firefox ESR (latest version is now 60).
Internet Explorer 11.
Java Runtime (jre) (32-bit)
In addition to one of the above 32-bit browsers, you will also need 32-bit java runtime.
Java runtime (x86)versions 6 and 7 both still work.
Once java runtime is installed, you need to enable the add-in from your browser.
User avatar
Wayne L
Country: Taiwan
Post by Wayne L » June 2nd, 2019, 11:31 pm
You can try delete cache or just run from Java control panel.
Wayne Liao
Senior Application Engineer
+886-3-5729077 ext332
