Keithley 2612: Error code -314 at startup sequence
Andre Rocke
Post by Andre Rocke » February 6th, 2019, 2:49 am
Hi, I work with a 2612A which recently started to show an error message -314 "save/recall memory is lost" at the end of the power-up sequence. The device then goes to normal operation and can be used without any problems. Anyhow I am a bit worried if there is eventually an issue with the hardware.
How can I get rid of this message?
Thank you!
Re: Keithley 2612: Error code -314 at startup sequence
Post by Andrea C » February 26th, 2019, 3:55 am
There are ultra caps for the memory such as user defined setups.
Try saving a user defined setup to one of the locations.
If the ultra caps are no longer charging, the nvmemory content is vulnerable.
To get rid of error, the parts need replacing.
Users browsing this forum: Bing [Bot] and 8 guests
