Keithley 2612: Error code -314 at startup sequence
Andre Rocke
Post by Andre Rocke » February 6th, 2019, 2:49 am
Hi, I work with a 2612A which recently started to show an error message -314 "save/recall memory is lost" at the end of the power-up sequence. The device then goes to normal operation and can be used without any problems. Anyhow I am a bit worried if there is eventually an issue with the hardware.
How can I get rid of this message?
Thank you!
