Timeout attempting to flush the instrument's output buffer error. Connect PC to 2634B using TCPIP
hung.nguyen.hvn
Country: Singapore
Post by hung.nguyen.hvn » September 9th, 2020, 7:00 pm
I am trying to connect from my PC to a 2634B SMU using TCPIP. The IP address is 192.168.0.4, port number 23, using TestScriptBuilder.
However, it has the error as attached.
Failed to open instrument.
VISA reports:
Timeout attempting to flush the instrument's output buffer.
Anyone encountering this problem before. Can help? Thanks.
Re: Timeout attempting to flush the instrument's output buffer error. Connect PC to 2634B using TCPIP
Post by Andrea C » September 23rd, 2020, 9:15 am
Port 23 is the telnet port. That will not be compatible with the VSIA based connection.
I'd recommend to use the LXI VXI-11 port: 5025
