Series 2600B Firmware 3.4.0 Released
Locked
Stuart M
Keithley
Keithley
Post by Stuart M » April 29th, 2021, 2:49 pm
New firmware version 3.4.0 for the Series 2600B System SourceMeter instruments has been released.
Download link for the new firmware can be found below. This release contains the following changes:
Changes In This Release:
The embedded web applications (Virtual Front Panel, Flash Upgrade, TSB Embedded) which relied on an outdated and unsupported version of Java have been re-implemented using modern web technologies to no longer depend on Java. (TSP Express was removed).
Note: that the new web applications are only functional if the LAN password is blank or disabled for the web interface.
Notice:
This firmware is for the "B" version only.
These models are supported by the firmware: 2601B, 2602B, 2604B, 2606B, 2611B, 2612B, 2614B, 2634B, 2635B, 2636B
Do not install this firmware on the non "B" versions - it will cause the instrument to be inoperable, and will require it to be returned to a service depot.
Download:
Series 2600B Firmware v3.4.0 and Release Notes -- Do not install on non-B
https://www.tek.com/source-measure-unit ... ll-on-nonb
Locked
