Disabling Data logging on 2602a
keithleybath
Country: United Kingdom
Post by keithleybath » April 19th, 2012, 9:40 am
hello,
I am currently trying to use the 2602a just as a DC pulse output.
I have modified the original factory script PulseVMeasureI, commented relevant lines so 2602 doesn't store the meanured data in the buffer as I need it to run for 30 days at 200Hz.
function PulseVMeasureI(smu, bias, level, ton, toff, points)
    -- Default to smua if no smu is specified.
    if smu == nil then
        smu = smua
    end
    -- Save settings in temporary variables so they can be restored at the end.
    local l_s_levelv = smu.source.levelv
    local l_s_rangev = smu.source.rangev
    local l_s_autorangev = smu.source.autorangev
    local l_s_func = smu.source.func
    local l_m_autozero = smu.measure.autozero
    local l_m_filter = smua.measure.filter.enable
    local l_d_screen = display.screen
    -- Temporary variables used by this function.
    local l_j, l_tonwm
    -- Clear the front panel display then prompt for input parameters if missing.
    display.clear()
    if bias == nil then
        bias = display.prompt(l_volts_fmt, " Volts", "Enter BIAS Voltage.", 0, -l_max_volts, l_max_volts)
        if bias == nil then
            -- Abort if Exit key pressed
            AbortScript(l_d_screen)
        end
    end
    if level == nil then
        level = display.prompt(l_volts_fmt, " Volts", "Enter PULSE Voltage.", 1, -l_max_volts, l_max_volts)
        end
    end
    if ton == nil then
        ton = display.prompt("00.000E+00", " Seconds", "Enter pulse ON time.", 20E-3, 0, 20)
        if ton == nil then
        end
    end
    if toff == nil then
        toff = display.prompt("00.000E+00", " Seconds", "Enter pulse OFF time.", 20E-3, 0, 20)
        if toff == nil then
        end
    end
    if points == nil then
        points = display.prompt("0000000000", " Pulses", "Enter number of pulses", 10, 1, 1000000000)
        end
    end
    -- Update display with test info.
    display.settext("PulsingV")  -- Line 1 (20 characters max)
    -- Configure source and measure settings.
    smu.source.output = smu.OUTPUT_OFF
    smu.source.rangev = level
    smu.source.levelv = bias
    smu.source.func = smu.OUTPUT_DCVOLTS
    --smu.measure.autozero = smu.AUTOZERO_OFF
    --smu.measure.filter.enable = smu.FILTER_OFF
    l_tonwm = ton - (smu.measure.nplc/localnode.linefreq) - 250E-6
    -- Setup a buffer to store the result(s) in and start testing.
    smu.nvbuffer1.clear()
    --smu.nvbuffer1.appendmode = 1
    --smu.nvbuffer1.collecttimestamps = 1
    --smu.nvbuffer1.collectsourcevalues = 1
    -- Configure triggering.
    smu.trigger.arm.stimulus = 0
    trigger.timer[1].reset()
    trigger.timer[1].delay = l_tonwm
    trigger.timer[1].count = 1
    trigger.timer[1].stimulus = smu.trigger.SOURCE_COMPLETE_EVENT_ID
    smu.trigger.measure.stimulus = trigger.timer[1].EVENT_ID
    trigger.timer[2].reset()
    trigger.timer[2].delay = ton
    trigger.timer[2].count = 1
    trigger.timer[2].stimulus = smu.trigger.SOURCE_COMPLETE_EVENT_ID
    smu.trigger.endpulse.stimulus = trigger.timer[2].EVENT_ID
    trigger.timer[3].reset()
    trigger.timer[3].delay = toff
    trigger.timer[3].count = 1
    trigger.timer[3].stimulus = smu.trigger.PULSE_COMPLETE_EVENT_ID
    smu.trigger.source.stimulus = trigger.timer[3].EVENT_ID
    smu.trigger.source.linearv(level, level, 1)
    smu.trigger.source.action = smu.ENABLE
    --smu.trigger.measure.i(smu.nvbuffer1)
    --smu.trigger.measure.action = smu.ENABLE
    smu.trigger.endpulse.action = smu.SOURCE_IDLE
    smu.trigger.arm.count = 1
    smu.trigger.count = points
    -- Initiate the pulses
    smu.source.output = smu.OUTPUT_ON
    smu.trigger.initiate()
    delay(toff)
    smu.trigger.source.set()
    waitcomplete()
    delay(toff)
    -- Update the front panel display and restore modified settings.
    display.setcursor(2,1)
    display.settext("Test complete.")  -- Line 2 (32 characters max)
    smu.source.levelv = 0
    smu.source.rangev = l_s_rangev
    smu.source.autorangev = l_s_autorangev
    smu.source.func = l_s_func
    smu.source.levelv = l_s_levelv
    smu.measure.autozero = l_m_autozero
    smu.measure.filter.enable = l_m_filter
    delay(2)
    display.clear()
    display.screen = l_d_screen
end
then run it using the following code (a 3Hz run)
smua.reset()
smua.source.limiti = 2
smua.measure.nplc = 0.1
PulseVMeasureI(smua, 0, 20, 15e-3, 285e-3, 8640000)
it is working fine. but i am looking for a simpler/neater solution.
the requirements are:
to drive 20 volt load
to be able to vary the frequency between 0.01 to 200 Hz. (I am currently doing it by changing nplc value)
i don't need the measured current to be logged by 2602a so i can run it for 30 days straight without exceeding it's onboard memory
I see it looks similarto C: and I would love to learn it, but timeline for my project doesn't allow it.
Can you help?
Vince W
Re: Disabling Data logging on 2602a
Post by Vince W » May 22nd, 2012, 3:57 pm
This is not a typical way to use a 2602A source meter, though I believe it is possible. Have you contacted your local Keithley Applications Engineer to check availability for providing services? Here is a link to our sales offices: http://www.keithley.com/company/salesoffices
Users browsing this forum: Bing [Bot] and 5 guests
