High Current Meas, TCR for model 1651
gchristi1
Post by gchristi1 » February 12th, 2020, 8:52 am
For the Keithley Model 1651 50 amp shunt, there is a instruction sheet but no datasheet on your website.
What is the Temperature Coefficient of Resistance (TCR) ? I'm trying to compare performance with the Vishay Foil CSM Series of resistors.
I don't see a High Current Measurement section. This seemed to be the closest to my application question. Thank you.
Re: High Current Meas, TCR for model 1651
Post by Andrea C » March 30th, 2020, 5:59 am
The "blades" of the 1651 shunt are from an alloy called manganin.
https://www.isabellenhuette.de/fileadmi ... NGANIN.pdf
Users browsing this forum: Google [Bot] and 1 guest
