set_mode command
Dima92
Country: Israel
set_mode command
Post by Dima92 » July 29th, 2020, 3:12 am
Can somebody explain how i should use set_mode function with KI_AUTO_GND_PINS modifier in order to connect all unused pins to ground?
Can I write it in this way:
setmode(7072,KI_AUTO_GND_PINS,1);
Re: set_mode command
Post by Andrea C » August 11th, 2020, 9:37 am
What model tester is this?
I would think a conpin() type command is more appropriate than set_mode().
