Quasi 4-probe measurement
JCP2017
Post by JCP2017 » May 30th, 2017, 3:29 pm
When using a 2400 purely as a voltmeter (say, to measure hall voltage) can one reduce the leakage current into the DUT by shunting a resistor across In/Out Hi/Lo and then only connect Sense Hi and Lo to the sample while using remote sensing or would this cause unreliable readings?
Re: Quasi 4-probe measurement
Post by Andrea C » June 11th, 2017, 5:18 am
Have you tried it?
Keep in mind that there is a max allowable delta v between the force and senses leads. Using them in this "uncoupled" way could result in some odd behaviors with certain complex loads.
