Getting Info from GPIB Keithley 2015-P
gjw1ikon
Country: United Kingdom
Post by gjw1ikon » September 13th, 2012, 9:39 am
Looking for a spark of inspiration, My Problem
I have a Keithley 2015-p Connected to an Agilent 3070 ICT Tester via GPIB,
I can Communicate with 2015-P but my problem is how do I take a measurement
and transfer it into PC over GPIB bus, using BT Basic.
This may seem silly but I am new to GPIB.
I have a simple Battery connected to The Keithley reading 6V how do I get
this info (6V) into BTBasic across GPIB Bus.
Any help would be amazing...
Re: Getting Info from GPIB Keithley 2015-P
Post by Dale C » September 13th, 2012, 11:42 am
The Keithley Model 2015-P is an IEEE-488.2 machine.
This means it responds to SCPI commands (Standard Commands for Programmable Instruments).
And since it responds to SCPI commands , in order to get data from the unit you must send a query?
Send the following query command via GPIB WRITE.
:READ?
then address the instrument to talk with a GPIB READ.
Then the data will come back.
There are many types of queries
:FETCH?
:READ?
MEASURE?
and so on.
READ? Is probably the most popular.
gjw1ikon
Post by gjw1ikon » September 14th, 2012, 2:14 am
How do I run these commands, Do I need speacial Software installed.
Post by Dale C » September 17th, 2012, 7:28 am
Most GPIB controllers are shipped with some basic control program to send commands and read data.
The Keithley KUSB-488B is a USB to GPIB adapter.
This connects to the USB port on your PC and the other end is a GPIB connection.
The KUSB-488B is shipped with the control program "KI-488 diagnostic tool".
With this you can send commands and read data.
I would expect the GPIB card you have has something similar.
