I may have some problems with the Labview drivers or configuration. Could somebody help me ?
I need to measure a sensor signal (+10v to -10v) with a Kusb 3108 and a Labview application
When the sensor is in repose the output signal is between 1.72 V and 1.74v.
I get the same values if I measure with a voltimeter or with the "Quick data Acq" software
but if I use LabView 9 and "AinSingle.vi" example (from LV-Link) the output signal is between 7.9 V and 8.1v.
What is wrong in my measurements ??
Best regards
Pablo
Voltage measurement Kusb 3108 Labview
- Country: Argentina
Re: Voltage measurement Kusb 3108 Labview
I've found the problem, I need to set a diffential input in the LaBview aplication for my sensor.
Could somebody tell me how to set that ?
you can select it in the VI. there is option of single-ended or differential
Users browsing this forum: Google [Bot] and 1 guest
