Use as electronic load
Model 2651A
tylerl
Post by tylerl » January 16th, 2015, 8:53 am
I want to use the 2651A as an eletronic load (current sink). I am setting the 2651A to source V and measure I. Voltage is set to 0V current limit is set to 1A. I'm applying 3V to output high terminal and 0V to output low terminal. I am measuring -1.118A not 1A. I confirmed that the 2651A is sinking 1.118A so the measurement is correct but the current limit is not. Trying different current limits results in different errors. Am I doing something wrong here?
Re: Use as electronic load
Post by Andrea C » January 16th, 2015, 9:07 am
Try sending the smua.source.sink = smua.ENABLE command.
The current compliance limit feature is by default less accurate for sinking power than sourcing power.
This command will improve the accuracy of current limit when sinking power.
tylerl
Post by tylerl » January 16th, 2015, 9:12 am
Thanks for the quick reply! That's what it was.
