Noise on the output of 2651A
Model 2651A
tommyhsieh
Country: Taiwan
Post by tommyhsieh » March 11th, 2018, 11:40 pm
Hi
I used a Keysight oscilloscope DSO-X 2004A to monitor the output of 2651A and I found it is noisy no matter I use 2-wire or 4-wire configuration.
The screenshots as below. Can anyone tell me it's normal or not?
DC_0V_2-Wire_noise_level with 5-Ohm resistor
https://photos.app.goo.gl/h7hpOBZcuEFwScdk2
DC_0V_4-Wire_noise_level with 5-Ohm resistor
https://photos.app.goo.gl/ShTomBUcnf4D9gux1
Noise level when generating pulsed current, 5-Ohm resistor is connected (600mA, 2-wire, 100mA bias)
https://photos.app.goo.gl/4c8OmnvcutdH583M2
Thanks and Regards,
Tommy
