Error5028 when running the attached vi
Model 2651A
yudong123
Post by yudong123 » November 29th, 2018, 2:25 pm
Hi guys,
I have trouble running my vi that I attached when I set stop current as 50A. 2651A display error 5028. I could run it just fine when set the stop current as 20A. The vi basically run the script I wrote to run pulse current sweep and measure iv. But i dont think KIPulse factory function can work with autorange so I wrote my own.
smu = smua
starti = 0.1
stopi = 50
points = 50
ton = 200e-6
toff = 0.5
NPLC = 0.01
reset()
smu.reset()
smu.nvbuffer1.clear()
smu.nvbuffer1.appendmode = 1
smu.nvbuffer1.collecttimestamps = 1
smu.nvbuffer1.collectsourcevalues = 1
smu.nvbuffer2.clear()
smu.nvbuffer2.appendmode = 1
smu.nvbuffer2.collecttimestamps = 1
smu.nvbuffer2.collectsourcevalues = 1
smu.source.output = smu.OUTPUT_OFF
smu.source.func = smu.OUTPUT_DCAMPS
smu.source.autorangei = smu.AUTORANGE_ON
smu.measure.autorangei = smu.AUTORANGE_ON
smu.measure.autorangev = smu.AUTORANGE_ON
smu.measure.autozero = smu.AUTOZERO_ONCE
smu.measure.filter.enable = smu.FILTER_ON
smu.measure.filter.count = 3
smu.measure.filter.type = 1
smu.measure.nplc = 0.01
smu.measure.delay = ton - 0.000166 - 20e-6
smu.sense = smu.SENSE_REMOTE
trigger.timer[1].count = points - 1
trigger.timer[1].delay = ton+toff
trigger.timer[1].passthrough = true
trigger.timer[1].stimulus = smua.trigger.ARMED_EVENT_ID
trigger.timer[1].clear()
trigger.timer[2].count = 1
trigger.timer[2].delay = ton - 3e-6
trigger.timer[2].passthrough = false
trigger.timer[2].stimulus = smu.trigger.SOURCE_COMPLETE_EVENT_ID
trigger.timer[2].clear()
smu.trigger.source.lineari(starti, stopi, points)
smu.trigger.source.limitv = limv
smu.trigger.measure.iv(smu.nvbuffer2, smu.nvbuffer1)
smu.trigger.measure.action = smu.ENABLE
smu.trigger.endpulse.action = smu.SOURCE_IDLE
smu.trigger.endsweep.action = smu.SOURCE_IDLE
smu.trigger.count = points
smu.trigger.arm.stimulus = 0
smu.trigger.source.stimulus = trigger.timer[1].EVENT_ID
smu.trigger.measure.stimulus = 0
smu.trigger.endpulse.stimulus = trigger.timer[2].EVENT_ID
smu.trigger.source.action = smu.ENABLE
smu.source.output = smu.OUTPUT_ON
smu.trigger.initiate()
waitcomplete()
Can anyone help me figure out why?
Yu
265xPulseLinearI.vi
(30.41 KiB) Downloaded 145 times
