Sine waveform
Model 2651A
jaime3008
Country: Chile
Sine waveform
Post by jaime3008 » July 20th, 2012, 7:58 am
Dear Sirs,
I have evaluating use the 2651A device for a application of generation and measurement of power AC signal with following features:
Voltage Range: 0-10 V
Current range: 0-20A
Frecuency range: 0 - 1 MHz
I need support for this device
Best Regards,
Jaime
Kenneth P
Re: Sine waveform
Post by Kenneth P » July 20th, 2012, 1:56 pm
Hello Jaime,
The 2651A is a High Current DC Sourcemeter. It is capable of pulsed high current however it is not capable of generating a sine wave. There is one exception using a list operation to simulate a sine wave where each point in the list would be an equivalent to a point in the sine wave. The limitation of the list operation simulation is that the rate will only be about 60 Hz with reasonable resoltuion.
