Just look at the attached chart. The red line is that of the voltage during charge and discharge. During discharge, you notice that it goes below 0. As far as I know I'm not able to set this up on TSBexpress and it's pissing me off.
But trying to do this on TSB express software is just making it difficult for me. Perhaps I need to configure a SDM routine on this instead of doing a single Sweep measurement. Anyways, I had created an excel file with 1000 data points to charge and discharge the battery at a constant current. During this time, I can specify what should be the compliance voltage. If I put in say 1.1V, then I can charge my battery up to this volt, but when I discharge it, it goes to negative voltages. In other words I need to setup an "Asymmetric compliance limit". I mean it seems like its such an obvious thing to do, but I can't figure it out on this software. So i want the upper CMPL Voltage limit set at 1.1V during sourcing, but when sinking, I want this CMPL voltage set at 10mV. So I am discharging at a constant current, but I want it to stop at specified compliance voltage limit. I don't want it going negative. So I need an option for this low voltage cut off limit. How do I get this setup. Please HELP..... I have attached here a result of a battery charge and discharge cycle. You notice how this cycle drifts downwards. This is because it is going in a negative voltage territory. This will damage my battery. Right now the software that came with Keithley doesn't give me an option to specify this. So please Help. here are my parameters.
Charge the battery at constant current, 5 to 10 mA, until the voltage reaches the compliance voltage of say 1.1V, then immediately start discharging it at 5 or 10 mA, until it reaches a low voltage cut off limit of around 10mV. Then Repeat this cycle again 10 more times. This is what I'm trying to configure. If you have a SDM or any other project file that can do this, could you please share by emailing it to me at [email protected].
Aneil
