reading interlock
Model 2657A
dumas_brian
reading interlock
Post by dumas_brian » September 15th, 2016, 3:49 pm
Quick question. It appears that f I want to read the status of the interlock, I can either 1) connect pin 24 of the digio to one of the first 14 pins (to read the pin if it is high) or look at the error message. Is this correct?
Thanks, Brian
Re: reading interlock
Post by Andrea C » September 20th, 2016, 5:31 am
You can also interrogate the state of status.measurement register set.
Bit11 will reveal the interlock state.
Bit11 = logic 0 state = interlock not asserted; source output prevented
Bit11 = logic 1 state = interlock asserted; source output permitted
If you just want to read the present state of the interlock, read the condition register of this register set:
print(status.measurement.condition)
or
print(bit.bitand(status.measurement.condition, 2048)) -- logical AND with 2048
or
print(bit.test(status.measurement.condition, 12)) --one based bit position
