what is the "VoE"?
Model 2657A
Simsangmin
Country: South Korea
what is the "VoE"?
Post by Simsangmin » September 17th, 2018, 1:09 am
hello
I saw keithley 2657A sourcemeter's current accuracy specifications
what is the "VoE"? :?:
Re: what is the "VoE"?
Post by Andrea C » September 28th, 2018, 12:08 pm
The VoE should be interpreted as the operating voltage. It applies to the performance specs of the three lowest current ranges.
In simple terms, it could be thought of as a term to account for leakage current which will be a function of the applied voltage. For example, the 1nA range will have an adder of 1fA per volt.
The Specification document (vs. Datasheet) is a little more clear:
2657A Specs
