pulse specs for 2657A
Model 2657A
guangchen08
Post by guangchen08 » July 12th, 2012, 4:15 pm
What is the pulse specs for 2657A? can it generate a single pulse with rise time (20ns), pulse width (0.1us), amplitude (up to 200V, 2kW)?
Thanks!
Regards,
Guang
Jane S
Re: pulse specs for 2657A
Post by Jane S » July 13th, 2012, 12:03 am
The data sheet of 2657A is attached below;
http://www.keithley.com/support/keidoc_ ... Data+Sheet
2657A is a Source Measure Unit and not a Pulse Generator. Therefore, the answer to your question is NO.
It will be great if you can expand on your measurement and application. Why do you need a fast rise time, narrow PW at high Voltage amplitude?
guangchen08
Post by guangchen08 » July 13th, 2012, 9:26 am
Thanks for the reply, Jane.
I am actually looking for a high power pulse generator. I thought 2657A can do it. Can you recommend a pulse generator for a single square pulse with 0.1us to 20us pulse width and up to 2kW power?
Jane S
Post by Jane S » July 20th, 2012, 7:49 am
Check Auriga or -. They might have something for you. It might be worth checking TLP approach systems like Barth pulser.
