Pulsed ITM returns no data
ondrejs
Country: Slovak Republic
Post by ondrejs » August 2nd, 2021, 5:14 pm
We are trying to carry out pulsed IV measurements using ITM on a two-terminal device. However, no data are reported from the test (in the sheet or the graph), as if no measurements were executed at all.
The test runs quickly (1-2 seconds). It reports no error. We tried connecting DUT via 1-channel and 2 channel setups (of the same PMU). No success in either setup.
Any idea about possible cause?
Thx, -Ondrej
ondrejs
Re: Pulsed ITM returns no data
Post by ondrejs » August 9th, 2021, 2:01 am
Attached screen shots after running the test, which show the definition of the test (1st image) and results (2nd image) which show that no data was collected.
Post by Andrea C » August 12th, 2021, 6:34 am
The ITM definition seems fine.
Close KITE and invoke KCON. Run the selftest for the 4225-PMU. Any errors?
I am suspecting some sort of hardware malfunction.
