KTEIv8.2 Installation on 4200-SCS System
radustoian
Country: Romania
Post by radustoian » April 3rd, 2013, 11:40 pm
I had to reinstall Windows XP and SP3 on one old 4200-SCS System and I wanted to install KTEIv8.2 from the manufacturer's original CD.
After running the set-up I received the following error message
"Initialization has detected that the destination machina is not a 4200 Semiconductor Characterization System. KTE Interactive can only be installed on a 4200-SCS. Installation aborted"
Does anynone can help to solve this? What special settings do I have to do in Windows XP in order to declare the system as 4200-SCS?
What exactly the KTEI installer looks for? A file or a registry key?
Thanks and best regards,
Radu
Jane S
Re: KTEIv8.2 Installation on 4200-SCS System
Post by Jane S » April 16th, 2013, 9:05 pm
Hi Radu,
It is not clear what else changed after you re-installed Windows to the system. Who knows? Something could have been changed before installation. Why do you have to re-install Windows? I think it is best to contact the nearest Keithley 4200 service office to you. At times, starting from scratch is best.
Jane
tarekss
Country: France
Post by tarekss » April 22nd, 2014, 3:05 am
Hi Radu, I have the same problem, did you found a sollution? thank you.
Return to “4200-SCS Semiconductor Parameter Analyzer”
