How can I use 2450 for realtime Resistance measurement (R_T Curve)?
Model 2450, 2460
Theerapong
Country: Thailand
Post by Theerapong » May 13th, 2017, 10:46 am
I wolud like to use 2450 for realtime Resistance measurement (R_T Curve).
But, I am new user for Labview.
Please help.
brian.d.smith
Re: How can I use 2450 for realtime Resistance measurement (R_T Curve)?
Post by brian.d.smith » May 15th, 2017, 4:52 am
The front panel is real-time. You can swipe the screen left and right to see a graph and see cumulative statistics.
Press the menu button and then press the graph button to configure settings for graph (Scale) axes. For X-axis I use "All" and for Y-axis I use "SmartScale".
Theerapong
Country: Thailand
Post by Theerapong » May 16th, 2017, 10:51 am
I have to check the R_T signal for a long peroid of time, let say 2-3 day.
So, how long or how many data point that i can store in the 2450 smu memory?
Can I store the data directly to USB during measured the resistance or other signal?
brian.d.smith
Post by brian.d.smith » May 16th, 2017, 8:48 pm
From the 2450 Reference Manual page 3-13
....you are limited by available memory in the instrument and the overall total capacity of all the buffers
stored in the instrument cannot exceed 1,000,000 readings.
So, for 3 days, 1,000,000 readings is about 4 readings per second.
Theerapong
Country: Thailand
Post by Theerapong » May 17th, 2017, 6:51 am
thank you for your kindly help and useful information.
Return to “2450/2460 Touchscreen SourceMeter”
