Configure 2460 Sweep Functions using LabVIEW
Model 2450, 2460
adekruif
Post by adekruif » August 10th, 2020, 3:44 pm
I have a LabVIEW program setup to control a 2460 unit to source voltage and read in corresponding current. I have the program working as intended, but I have been asked to add in the sweep capability as well.
I have located several sweep VIs that will work for my application but have been unable to get them to return the values I am expecting. My question is after setting up all the parameters for the sweep (delay, count, points, etc.) do I have to trigger the sweep to start or does it start automatically? From the initial testing I have done, it appears to need a trigger to start but I don't know which of the 40+ triggers to select.
Any help would be appreciated!
Return to “2450/2460 Touchscreen SourceMeter”
