Trigger Model - Exercise 1
Models 2450, 2460, 2461, 2470
Post by Andrea C » December 30th, 2020, 9:56 am
Here is some intro info to familiarize with the trigger block programming in 2450 or similar touch screen models.
Hook a scope probe to digital output line 1 on the DB9 connector on rear of instrument (pin 1 = +, pin 9 = GND).
Use TSP command set.
The digital line has a pull up and will read 5V normally. This script will strobe it low for 100usec duration every 1 msec.
The script will loop 500 times.
loopCount = 500
delayDuration = 1e-3  --500e-6
trigger.model.load("Empty")	--load an empty trigger model as to clear all trigger model blocks
 --setup digital output to strobe when NOTIFY2 event occurs
digio.line[1].mode = digio.MODE_TRIGGER_OUT
trigger.digout[1].pulsewidth = 100e-6
trigger.digout[1].stimulus   = trigger.EVENT_NOTIFY2
trigger.model.setblock(1, trigger.BLOCK_NOTIFY, trigger.EVENT_NOTIFY2)  -- strobe the digital output
trigger.model.setblock(2, trigger.BLOCK_DELAY_CONSTANT, delayDuration)
trigger.model.setblock(3, trigger.BLOCK_BRANCH_COUNTER, loopCount, 1)  -- go back to block 1
trigger.model.initiate()
The results in the following trigger blocks:
trigger blocks
A scope capture:
scope capture using KickStart software
Here is scope capture with the delay duration of 100usec and the digout pulse width set to the default/minimum of 10usec.
10usec strobe, 100usec period
Return to “2450/2460/2461/2470 Touchscreen SourceMeter”
Users browsing this forum: michaelkopitin and 1 guest
