Measuring more than 10k values over time
I am during drift measurements of some mosfets using 2 2450 smus with kickstart to setup the gate and drain biases. I am loging the current over time.
I want to measure for 3 days every 1sec, but I just noticed that kickstart does not allow more than 10000 points while 2450 can log almost 7 million points. Why is there such incompatibility, how can I setup my measurement to log approx. 300000 points? Is it possible to increase the number of points in kickstart?
P. S.
To sample every 1 sec I should set the delay to 1 sec, correct? Because if I include timestamp loging, it does not increment by 1 sec between measurements.
P. S.
Re: Measuring more than 10k values over time
A simple software loop will not be exactly synchronous to any clock. The trigger model is designed to be used when synchronous behavior is required. If you want to have exactly 1 sec increments, I believe that you would need to use the trigger model.
Maybe exactly 1sec is not needed, but what about the problem with number of points, any way to increase it?brian.d.smith wrote:A simple software loop will not be exactly synchronous to any clock. The trigger model is designed to be used when synchronous behavior is required. If you want to have exactly 1 sec increments, I believe that you would need to use the trigger model.
HI allse87,
You are correct. The current limitation of data points is 10k. There are a variety of reasons for this limitation. We are working to increase the number of data points KickStart can store in a future version. However, that won't help your immediate test needs. I'll send you a private message to follow up.
Jennifer Cheney
Jennifer Cheney
Also, the "delay" parameter does control the approximate time between data points. If you want 1 sec delay between data points, then set the delay to 1 sec.
