230 Programmable voltage Source
jcrouse
Post by jcrouse » February 7th, 2012, 8:00 am
The spec says max of 0.5 V drop in the sense lead. Does this mean a max of 0.5 V between the sense lead and the power suppy output?
What happens if this value is exceeded?
The spec says max of 5 Ohms in the sense lead. Does this mean a max of 5 Ohms between the sense lead and the power suppy output?
Jim Rouse
Re: 230 Programmable voltage Source
Post by Dale C » February 7th, 2012, 8:26 am
1.Max of 0.5V drop in the sense lead means if there is more voltage dropped on the sense lead then the output voltage would not meet spec.
2. Same with 5 ohm max in the sense lead. the more resistance the more voltage will be dropped across the sense leads.
