I'm trying to use the Keithley 2002 Single Read .vi in a larger labview instrument and it's taking way too long to retrieve data. Is there a quicker way to retrieve the information using labview? Or any other way to speed this up? I'm trying to obtain a VDC reading from the instrument.
Thank you.
Keithley 2002 LabVIEW Single Read .vi
- Country: United States
- Keithley Applications
- Contact:
Re: Keithley 2002 LabVIEW Single Read .vi
Not sure why it is taking so long.
But you could always send SCPI commands with either VISA or GPIB write.
:SENSE:VOLT:NPLC 1 Integration rate of 1PLC
:SENSE:VOLT:AVER:STAT OFF Disable the filter
:SENSE:VOLT:RANGE 1 Select the 1V range
:READ? Query the 2002 for data
Now read it with a VISA or GPIB read.
These commands would help speed things up.
Thanks Dale I'm not sure why it took so long either I did end up doing what you said, I think a little different, to get it working and its much quicker now. Thank you
